Camera images from Automation measurement system and from Labview are different
I'm currently using a Basler camera to capture some images every time. So usually, from the Automation measurement system, I changed the camera attributes values (shutter, brightness, gain, white balance). Then, I go to the Labview VIs and input the exact same values which I got from Automation measurement system. Even though all the setting values are the same, the image I can see from the automation measurement system is completely different from what is captured from the Labview VI. I don't understand this. Could you give me any advice to solve this problem?
Thanks!
(4,209 Views)
Could you upload a screen capture of the difference? It's hard to say without more info on what the camera is doing.
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
(4,145 Views)
