Can 2 programs use 2 different DAQmx tasks to talk to the same cDAQ module?
I have a DASYLab program that is running a test and collecting data.  I would like to use a LabVIEW program with a PID controller to control a valve at the same time using an NI-9264 module.  Is this possible?
Jim
LV 2020
(1,970 Views)
Not if they share resources. If one program is only doing analog input and the other program is only doing analog out, then you probably can use both programs at the same time. If they are are both trying the same task, then no.
mcduff
(1,883 Views)
