Can DAQ USB 6009 generate 1KHz output?
Hello, I need to generate a squre signal with 1KHZ frecuency using NI DAQ. Does anyone know if this is possible using NI DAQ USB 6009?
Ali
(3,392 Views)
Have you looked at the specs? Both the analog out and digital I/O are software timed. The analog out is specified as 150 S/s and I think the best square wave you could probably get with the digital I/O is around 500 Hz and that would have significant jitter.
(3,390 Views)
Hi everyone.
The next link can help you to calculate the maximum output frequency based on the maximum sampling rate of the 6009.
Hope this helps.
Israel B.
AE Mexico.
(3,369 Views)
