Can I Connect My NI USB-6251 to the DAQ Signal Accessory?
I' ve got the standard NI USB-6251 with the integrated screw terminals to replace the NI-PCMCIA 6024. Now I still want to use our DAQ Signal Accesory if it's possible. If I unscrew the top section of the NI USB-6251 there is a 50 pin and 34 pin connector. Is there probably a possibility to connect a NB1 50-pin ribbon cable from the P1 connector of the NI USB-6251 to the 50-pin MIO Device connector on the DAQ Signal Accessory?
Where can I find the Pinouts for the 50 pin (P1) connector in  the NI USB-6251 - Device?
(3,118 Views)
I would think that thi is not a supported way to replace the built in screw connector with a cable and connect it to a DAQ Signal Accesory.
Perhaps you can have a look in our device manuals at ni.com/manuals but I would consider to replace the DAQ Signal Accesory with the built in srews. That would be less work to do!
Best regards
Alex R
NI Switzerland
(3,089 Views)
