Can I assign separate channel for each line in 6508
I am able to make a DIO channel only for Port, not for line in 6025E.
Can I make a channel for each line in 6508?
(2,559 Views)
Hello;
The DAQ device you are working with is based on the 8255 chip. That chip doesn't allow addressing on a line by line basis but on a port by port basis. That is why you can't create a channel for each line, only for each port.
Regards
Filipe A.
(2,559 Views)
