Can I connect and read a linear glass scale that has a TTL output with a USB-6212
As the subject says I would like to connect a linear glass scale to a USB-6212 so that I can use the output in Labview to monitor linear position.  The pinout for the linear scale cable is as follows:
pin 6 A+ Yellow
pin 1 A– Orange
pin 8 B+ Green
pin 3 B– Blue
pin 9 I+ Brown
pin 5 I– White
pin 7 +5V Red
pin 2 0V Black
pin 4 Shield
I also am using a UMI-7774 to connect 4 Kolmorgen drives (AKD) to a PCI-7344 board to control them through labview.  If I an unable to connect through the USB-6212 can I use the UMI?  If anyone knows if I can do this please explain how.
(5,150 Views)
Providing nothing but the color of the wires is hardly enough information. Provide the make and model of the sensor and the datasheet/manual.
(5,146 Views)
I was under the impression that the pinout would be enough.  I appoligize that it is was harder to see as the wire colors were right after the pin out information.  Here it is again without the wire colors.
pin 6 A+
pin 1 A–
pin 8 B+
pin 3 B–
pin 9 I+
pin 5 I–
pin 7 +5V
pin 2 0V
pin 4 Shield
It is a ZS Systems Glass Grating Linear Scale GT05.  Attached is the datasheet.
(5,137 Views)
The manual for the DAQ device has a section on how to use the counters for quadrature decoding.
(5,123 Views)
RTFM 8-16
just use the + ABI line
I=Z
and 0V to DGND
the scale needs 50mA , you can use the 4.5 5V output IF you are within the total power consumption... again RTFM
maybe the MAX assistant can help you, rigth click and create a new DAQmx task , choose the card, signals income, counter, counter0  and MAX will tell you where (PFIx) to connect the A,B,Z lines
Greetings from Germany
Henrik
LV since v3.1
(5,116 Views)
Henrick,
  ok Ill try that.  Thank you.
(5,113 Views)
