Hello, I need to control a driver board for my experiment.
The board I need to run is controlled by two ±10V analog voltage signal,
and one 7.2 kHz(let's say 8 kHz) ~3.3V TTL/CMOS33 clock signal. (50% duty cycle)
To do this, I have a USB-6002 DAQ device and Labview 2019.
I know I can make ±10V analog voltage using Labview and USB-6002.
But can I make 8kHz 3.3V TTL clock signal?
If yes, advice on implementing Labview code for that signal will be big help. (As I am a newbie to labview..)
If no, could you recommend other small USB controlled DAQ device, which can create both analog and TTL signals?
I thank everyone who read and comment on this discussion in advance 🙂
