Can I install Labview 2016 on an SD card?
can I install Labview on a SD card? I have a cDAQ-9132 with 15GB internal memory and Windows Embedded. Labview 2016 and Windows Embedded use 15GB memory. Sometime the system crashes.
Any suggestions?
Greetings from Germany
Johannes
(2,847 Views)
Hello joro_kl,
you can try this, changing the Installation folder and install software to a network or usb storage should work.
best regards
Alexander
(2,811 Views)
