Can I port a program for a CdaQ to a usb6008
I'm using a cDAQ-9178 with an ADC module and a Digital IO module to develop on. Is there any way to easily port the program for use with a usb6008?
(2,990 Views)
If you were only using the NI-DAQmx drivers on the cDAQ-9178, then the only thing you need to change is the NI-DAQmx task, change it to reference the NI USB-6008 channels instead.  This is assuming that the signals your measuring/creating are also within the USB-6008 specifications.
Nathan
Systems Engineer
SISU
(2,976 Views)
Thanks. That was easy
(2,971 Views)
