Can I route signals on a DAQmx simulated device?
I'd like to route simulated AO to AI on a DAQmx simulated device. Is this possible and how? If AO-to-AI is not possible, is it possible to route simulated signal ("Simulate Signal", etc.) to AI of a DAQmx simulated device?
Thanks in advance,
(3,648 Views)
Sorry, neither of these options are available in a DAQmx simulated device.
(3,635 Views)
Hi golubovski,
Dennis is correct. There is no way to do either of those using a DAQmx simulated device. The main purpose of the simulated devices is so that you can develop code for a piece of hardware that is not present in your development system.  They are not meant to help debug your LabVIEW code.  Physical signal routing is only possible when an actual DAQ device is present. I hope this explanation helps you and please let me know if you have any more questions.
Message Edited by Nathan_R on 03-03-2008 03:35 PM
Nathan
NI Chief Hardware Engineer
(3,608 Views)
