Can I run both Labview 6i and Labview 8.6 using NI-PCI-6503 on the same machine?
Thanks for all the help.  It appears that the easy solution isn't there'.  Since the 8.6 application has many of the same functions as the 6i application I decided the best and most durable solution was to incorporate the 6i application into the 8.6 application.
Again thanks for your help.
Message 11 of 11
(735 Views)
