Can I save a program into the cDAQ 9174? like in arduino
I have a proyect in wich I need keep the cDAQ 9174 working. And I want to know if I can save the program into the DAQ and It steel working without a computer whit LabVIEW. like in arduino, we write a program in It and steel working with this program. Thank you for your support
(3,370 Views)
Hi RogerLo,
Unfortunately that is not possible, you can't save a program in this particular chassis, you are going to need to have a PC conected in order to see and analyze the data comming from the modules that are connected in the 9174. The chassis can't work as an stand alone system. Hope you find this information helpful.
Luis G.
(3,345 Views)
Thank you so much Luis G. Have a nice day!!
(3,325 Views)
