Can I set cutoff frequancy of Analog Input Lowpass Filter?
I am using PCI 6221 with SCB-68 and LabView 8.0 and I am sampling   signal which frequency is 40kHz. Can  I change the cutoff frequency of the filter and how ????
(3,193 Views)
Hello Fazi,
It looks like your PCI-6221 doesn't have any built-in filters for the Analog inputs, but your SCB-68 provides a breadboard for adding additional circuitry.  Starting on page 5-7 of the SCB-68 User Manual it walks you through building a lowpass filter and choosing the correct resistor and capacitor types and values.  This will allow you to create a lowpass filter with any cutoff frequency you want.
Brooks
(3,179 Views)
