Can I use CVI 6.0 to access a PXI-6221 Card?
(2,913 Views)
Hi Bob,
Thanks for posting on the NI Discussion Forums!  Unfortunately, you cannot use LabWindows CVI 6.0 to access a PXI-6221 device.  The reason being is that this device falls under our M-series device family.  These device can only be programmed with NI-DAQmx.  The earliest version of LabWindows CVI that is compatible with NI-DAQmx is LabWindows CVI 7.0.  Your only options are to either upgrade LabWindows CVI, or use a device which can be programmed using our Traditional Daq legacy driver.  Let me know if you have any additional questions/concerns.
Rod T.
(2,880 Views)
