Can I use PFI lines for DIO in C# using DAQmx?
I haven't found a difinitive solution for this yet. I have all these free PFI lines. I know how to use them as input triggers (rising & falling edge detection), but I'd like to use them as general-purpose DIO lines (i.e read the current value, write a 1 or a 0 to it).
Is this possible? I'm using a 6052E.
Thanks!
John Duddy
(3,096 Views)
Hi John,
You cannot use PFI lines for DIO on an E series card. Please refer to the following KnowledgeBase for more information.
PFI Lines (E Series VS. M Series)
Thank you,
Simran K
(3,082 Views)
Perfect - that explains why people here disagreed - they probably worked with different cards in the past.
Thanks!
(3,079 Views)
