Can I use a 6259 Analog Input port to measure VAC?
Hello to ALL,
This will be used in only 3 Analog Input Ports. The rest will use VDC as input...
Thx N Advance
FredTest
(2,991 Views)
Of course you can up to the limits of the sampling rate and max voltage. Simply try the test panel in MAX. Assuming you are using LabVIEW, look at the DAQmx examples that ship with LabVIEW.
(2,973 Views)
