Can I use a USB-TC01 to measure voltage?
I am looking for a low-cost way to measure 0-30mV, and it looks like a NI USB-TC01 might be able to do this.  Can you set these up as standard AI lines?  Or can you only set them up to read temperatures.
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(4,189 Views)
I don't have one right now, so I can't say for sure, but I'm pretty sure you can do this.
It shows up just like any normal m-series DAQ device in MAX under devices and interfaces.  You can then create a virtual channel like you normally would to take an analog measurement off a thermocouple.  But I'm pretty sure you can just choose to take an analog voltage measurement off of the same channel.
(4,184 Views)
