Can I use my pda as a remote daq device?
We currently use a laptop (with a DAQCard AI-16XE-50 and a wireless network card) as a remote daq device. I'd rather use my pda. Is there a way to do this? I have an expansion pack for the pda that allows me to install 2 pc cards.
(2,915 Views)
Hi pkristop,
If the current set up works with the laptop (you're able to send the acquired data through the wireless network card), you can do the same on your PDA using the LabVIEW PDA module and DAQmx Base driver. The DAQmx Base is a driver that will allow you to build data acquisition applications that run on a PDA. You can find more information about the LabVIEW PDA module and the DAQmx Base driver from the links below:
LabVIEW PDA Module
DAQmx Base 1.x Getting Started Guide
Hope this helps!
Lesley Y.
(2,894 Views)
