Can I use the NI PCI 6013 under DOS mode?
I have a program for dilatometer measurements, which I wrote some years ago using Turbo Pascal for DOS. Now, I need to use the NI PCI 6013 card instead of old one (ISA card). It is possible to read the data from 6013 under the DOS?
Thanks in advance.
Anton.
(3,026 Views)
Anton,
NI-DAQ 4.8.0 was the last version of the driver to support DOS. The first version of NI-DAQ to support the PCI-6013 was 6.9.3. So, unfortunately, this will not be an option. Why do you need to use the PCI-6013? Maybe some alternative options exist.
Good luck with your application.
Spencer S.
(3,026 Views)
Ok, Could you advise me another PCI acquisition card? My task is read two DC signals, one from B-type thermocouple (mV range) and another one from ATA-2001 amplifier (+/- 10V range) with high precision (16-bit). I want to use my old program, which was wrote by Turbo PASCAL for Dos. These signals should be read simultaneously with the frequency around 1-2 kHz.
Anton.
(3,026 Views)
Anton,
Unfortunately, none of the PCI DAQ boards are supported under DOS because they are not compatible with NI-DAQ 4.8.0 or earlier. There are 16-bit ISA DAQ boards that NI-DAQ 4.8.0 supports. Are you required to use a PCI board? If so, you will need to perform register-level programming (does not require NI-DAQ) to use a PCI DAQ board in DOS.
Spencer S.
(3,026 Views)
