Can I view my devices in MAX without Labview Installed - usb 6009
I'm running an executable on my machine for the past few months and it was working fine. I have a usb 6009 connected and I had no problems throughout this time. After unplugging my device to move machine, the DAQ device seemed to have stopped working.  When I tried to troubleshoot in MAX, the device was not there. Must I have labview installed to view devices in MAX?  I'm wondering how this device worked all this while and then stop all of a sudden.
I will appreciate any suggestions.
(2,966 Views)
If MAX fires up, you have all the dependencies needed for it to run.
Sure the device is connected/powered?  "Plugged in, turned on" check done?
Bypass USB hubs, replace cables, etc.
(2,960 Views)
