Can I wire a BNC panlette to an SCC-FT01 in an SC-2345 that lacks configurable connectors?
Can I wire a BNC panlette to an SCC-FT01 in an SC-2345 that lacks configurable connectors? I can't tell from the panelette photos how they make signal connection to the conditioning modules in the connector-configurable version of the SC-2345. Wires? Board edge connectors?
Any help is greatly appreciated.
-Phil
(3,743 Views)
If you can take a photo to explain your problem, it'd be great. Normally, you need to wire the signal with wiring to module inside 2345. If you wish to make BNC connection, you need to do it outside 2345.
(3,734 Views)
I'm debating whether to purchase the BNC panelette (NI Part # 184737-01) for my SC-2345 (which is the type that lacks configurable connectors). I was wondering how it connected to an SCC conditioning module. I'd love to have a photo of its connectors (or a mechanical drawing). I'm askling if it makes a a board edge connection -- does it plug into a slot? Or is it necessary to run a wire between a panelette connector and an SCC module?
Phil G
(3,719 Views)
As described here, they have lead wires that you connect to the screw terminals.
(3,716 Views)
I missed that. Thank you very much.
-Phil G
(3,710 Views)
