Can PCI-NI4351 board work with Labview 8 windows XP?
I used 2 NiDAQ 7 CDs provided by NI, and NI4350/4351 Series CD to install to my new windows XP system (was used Windows NT), after I installed LV8.  Some problems that I have are:
1.  There are no error during installing NiDAQ, but MAX cannot detect the indteface board.  Also my windowsXP cannot detect hardware either.
2.  When I install Ni4350/4351 software, there is a window popup asking VI logger CD that I do not have it.  I click OK button, then it stop instalation.
My questions are:
1.  Do I use the correct Ni DAQ version?  Should I use tradition NiDAQ or niDAQmx?
2.  Can PCI-NI4351 board work with Labview 8 windows XP?
3.  Do I need to install PCI-NI4351 driver?
I need some advices regarding above problems. Thanks for all your helps
Henry
powerpcboard
(3,730 Views)
According to the driver support page, you need version 7.4.4 of the traditional driver on XP.
(3,723 Views)
Thanks, Denis.
Do I also need to install NI4351 driver?
(3,718 Views)
Sorry, that I don't know.
(3,716 Views)
The NI-435x driver is a wrapper for Traditional NI-DAQ that makes it easier to program a 4350 or 4351 device.  It's not required, but it makes things easier.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,712 Views)
