12-27-2006 09:57 AM
12-28-2006
01:13 PM
- last edited on
08-06-2025
08:27 AM
by
Content Cleaner
Hey Krishna,
There are a couple of things that you might want to look into. The specification sheet (once you open the .chm file, look under Device Specific Information -> NI 6722/6723 -> Specifications) says that the maximum update rate for 24 channels is 253 kS/s if you use the onboard memory (FIFO buffer) and 60 kS/s if you use your PC memory (RAM). I believe you have a total FIFO size of 2047 samples (you will have divide that by the number of channels you are using, I.e. 2047 Samples / 24 channels = 85 S/channel).
So if you want to use the onboard FIFO, then you will have to cut down the output waveform for each channel to 85 Samples or you will have to slow your update rate for each channel to 60 kS/s if you want to use your computer RAM.
Wish you a Happy New Year.
Malay Duggar
NI
Message Edited by 50ohmTerminator on 12-28-2006 01:14 PM
