Can cdaq-9174 be used with labview 7
Can/how can I use the cDAQ-9174 with Labview 7.1.
I have read through the documents I can get my hands on.  It appears DAQmx 8.5 does not have the drivers for it and DAQMX 9.x does not seems to support Labview 7.
Am I missing something?
Axe
(3,296 Views)
Hi Axehandler,
You aren't missing anything.  There is not a version of DAQmx that supports both LabVIEW 7.1 and the cDAQ-9174.  In order to use the cDAQ-9174 you will need to upgrade to a newer version of LabVIEW and at least DAQmx 9.0.2.
Barron
Applications Engineering
(3,274 Views)
