Can faulty PCI Bus burn PCI DAQ cards ?
I have an industrial test equipment that runs 24/7.  This was commissioned in 2019 Nov.   It had an Advantech Industrial PC which had four PCI slots and I had used a PCI-6229 and PCI-6514 in two of them.
For no obvious reason the cards went up in smoke when the equipment was normally running. Initially I thought its a kind of short circuit or a 24V dc SMPS fault. But all of them checked out fine. And the PC by itself is now booting OK.
This is highly perplexing and I have sent the PC for a mother board check up.  But just wanted to know if anyone has faced a similar failure and if the PCI Bus can actually fry cards like this ? In fact I use this combination of cards for most of my industrial projects since 2000 and never had even a single failure.
Any pointers on how this could have happened ?  Attaching images of the fried cards.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(1,424 Views)
You didn't describe what is connected on the other side of the card i.e., external components and how the electrical connections are.
Santhosh
Soliton Technologies
(1,391 Views)
Judging that the majority of damage appears to near the I/O connector and the large amounts of black soot I am guessing high voltage or ground fault emanating from the equipment to which the cards were connected to,
-AK2DM
(1,381 Views)
