Can i mix the AI mode (DIFF, RSE..) on PCI-6229?
I want to known if it is possible to mix the mode off the AI .3 AI's in DIFF Mode and 3 AI's in RSE Mode.
If OK,will it affect signals of different channel ?
Thank you
(3,503 Views)
You can configure some of your channels for differential and some for RSE within a single task.  As long as all of your signals are grounded properly, you shouldn't run into any problems.
Alex Person
NI-RIO Product Support Engineer
(3,478 Views)
Can I use differential mode if the voltages I want to measure the difference of are <10V w/ respect to the AI GND?
The differential measurement shouldn't be more than 1-2V apart from each other, I'm just not sure if putting in a voltage so far away from AI GND will cause the ADC's to malfunction.
(3,329 Views)
