Can more than one PC connect to the cDAQ 9189 at a time?
In order to connect to my cDAQ properly, I had to reserve the chassis on the network (it said that the chassis had been reserved by another device).
But what if I want to PCs to connect the cDAQ at the same time? Is this possible?
(Just FYI the article below helped me connect to the cDAQ in the first place):
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kEkPSAU&l=en-US
(1,282 Views)
No, only one PC can perform operation on the 9189:https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6xUSAS&l=en-US. Once it is reserved, other PCs can add it to the system and look at the system information from MAX but cannot perform any driver operations. However, the other PC can force reserve the 9189 though, but that will stop any ongoing driver operations on the 9189.
(1,239 Views)
Great, thanks for the info on this! ^_^
(1,225 Views)
