Can not download VB6.0 examples for DAQmx
I'm trying to find the VB examples for using DAQmx.
I know, there is a knowledge base entry explaining that this doesn't download automatically, and you need to do set it to download manually, but I did that, and even though the installer says it is installed, I can't find the directory.
Any more straightforward source for a few VB examples -- I'm trying to do something really simple (just read an analog voltage).
Thanks!
(3,049 Views)
Accepted by topic author JoeLichy
The following link describes where to find the help file as well as where the examples are installed:
http://digital.ni.com/public.nsf/allkb/B22FE2B0F9C8935286256E920073DA07
And more documentation on where to find examples:
http://digital.ni.com/public.nsf/allkb/735848148B5B4964862571F5004692C7?OpenDocument
Hope this helps!
Systems Engineer
SISU
(3,038 Views)
