Can not find NI9237 module in DAQ assistant or MAX but its visible project explorer
Hi Guys,
as in the title already stated I have problems finding the NI-9237 module in the DAQ assistant or in the MAX (see pics) althougth the module is visible in the project explorer (see pic) when starting new project. I want to use the NI9237 module to measure temperature via a half-bridge setup but cannot find the analog inputs when using the assistant.
Currently I am using a cRIO-9014 in a cRIO-9114 chassis with just two addtional modules (NI-9476 and NI-9237). The NI-9476 I/O module works perfectly (can control fans and heating elements) but was not able to get the NI-9237 module running via the DAQ assistant.
Would be grateful for any information or hint to a solution of my problem.
Thank you very much!
Purtschomatic
(2,674 Views)
Still having issues trying to get the module running.
Anybody has a clue what I can do to get it working?
Thank you!
(2,624 Views)
Hi Purtschomatic,
the DAQ Assistant will only work if you use the module in a cDAQ chassis. You are using it in a cRIO chassis.
It is also expected that you do not see all modules plugged in a cRIO in MAX.
You can use an example for cRIO programming with 9237 instead. These examples are found in LabVIEW:
Help >> Find Examples >> Hardware Input and Output >> cRIO >> Module specific
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(2,569 Views)
