Can not read a signal on the deployment device
Hi, dear all:
   I got a weird problem these 2 days. Need your kind helps.
   I've developed a program which reads input digital singals, and it works very well at my computer.
   After deployed the program on another computer and installed all drivers what it needs.
   First, I've tried reading signals in MAX, it works and I can see the incoming signals.
   But when starting program on that computer, the program only can do the function of writing files,
   but can not display any incoming data (using DAQmx Read (Digital 1D Bool 1Chan 1Samp).vi).
   So, my question is although I could see incoming signals through MAX(using "TestPanel"), how come it could not work with
   my program? As the problem says, I might wonder DAQmx Read.vi has some problems, but the thing
   is this program works very well on my developing computer.
   Definitely sure that the program works fine at my developing computer.
   Is there anyone could help me figure out this "weird" problem for me, please?
   The information of developing computer as the following:
   Windows XP SP2, Labview 8.2, 6036E multifunctional DAQ card
   The deployment computer:
   Windows XP SP2, Labview 8.2 runtime library and DAQmx 8.3 drivers installed
Thank you so much for watching this problem.
Best regards!
(2,830 Views)
Andy,
Can you post a screenshot of your code? Also, have you tried re-installing the DAQmx driver on that computer? You can get it from here.
Abhinav T
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(2,805 Views)
Also see this duplicate post of yours
(2,795 Views)
