Can somebody add digital output control to my program for USB 6008
I  have some simple program. It shows the voltage from AI. Now I would like to add responce to digital output. For example: I have a signal and when its level becomes higher than something I need to send +5V signal on digital output(to drive a relay, switch it on for some time).
I could not find samples or tutorials how to do it in one program. I am not experienced programmer so may be you can suggest something about my VI and to correct me if I am wrong.
Thanks. Sergey.
(3,164 Views)
Duplicate post, solution at:
http://forums.ni.com/ni/board/message?board.id=140&message.id=13260#M13260
(3,155 Views)
Sorry about duplicating post. I have tried to find my previous post today and could not(I have used search option and checked all posts for last 3 days). So I thought that It was either posted in different board or deleted.
Sorry again. Sergey.
(3,147 Views)
No problem.
An easy eay to find your (or anyone else's) posts are to click on your handle (Dr Zhdanov), then select 'Find all posts by this user' link on the page that opens up.
Have fun coding 🙂
(3,142 Views)
