Can't find the #include files...
Dear all,
Hi! I am very new in programming and i am assigned by the university to create a programm for the DAQ-Card NI6024E (in C++).I've been reading some example codes from the forum but in some cases i can't find the #include files that are included in the code. For instance in the following code where can i find the cvirte.h and DAQmxIOctrl.h? Should i have and .lib files too if there are any? :
* CVI Example program:
* ContAcq-IntClk.c
* Example Category:
* AI
* Description:
* This example demonstrates how to acquire a continuous amount of
* data using the DAQ device's internal clock.
* Instructions for Running:
* 1. Select the physical channel to correspond to where your
* signal is input on the DAQ device.
* 2. Enter the minimum and maximum voltage range.
* Note: For better accuracy try to match the input range to the
* expected voltage level of the measured signal.
* 3. Set the rate of the acquisition. Also set the Samples per
* Channel control. This will determine how many samples are
* read each time the while loop iterates. This also determines
* how many points are plotted on the graph each iteration.
* Note: The rate should be at least twice as fast as the maximum
* frequency component of the signal being acquired.
* Steps:
* 1. Create a task.
* 2. Create an analog input voltage channel.
* 3. Set the rate for the sample clock. Additionally, define the
* sample mode to be continuous.
* 4. Call the Start function to start the acquistion.
* 5. Read the data in a loop until the stop button is pressed or
* an error occurs.
* 6. Call the Clear Task function to clear the task.
* 7. Display an error if any.
* I/O Connections Overview:
* Make sure your signal input terminal matches the Physical
* Channel I/O control. For further connection information, refer
* to your hardware reference manual.
#include
#include
#include
#include
#include
#include
#include "ContAcq-IntClk.h"
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
static int gRunning=0;
static int panelHandle;
int main(int argc, char *argv[])
if( InitCVIRTE(0,argv,0)==0 )
return -1; /* out of memory */
if( (panelHandle=LoadPanel(0,"ContAcq-IntClk.uir",PANEL))<0 )
return -1;
SetCtrlAttribute(panelHandle,PANEL_DECORATION_BLUE,ATTR_FRAME_COLOR,VAL_BLUE);
SetCtrlAttribute(panelHandle,PANEL_DECORATION_GREEN,ATTR_FRAME_COLOR,VAL_GREEN);
NIDAQmx_NewPhysChanAICtrl(panelHandle,PANEL_CHANNEL,1);
DisplayPanel(panelHandle);
RunUserInterface();
DiscardPanel(panelHandle);
return 0;
int CVICALLBACK PanelCallback(int panel, int event, void *callbackData, int eventData1, int eventData2)
if( event==EVENT_CLOSE ) {
gRunning = 0;
QuitUserInterface(0);
return 0;
int CVICALLBACK RangeCallback(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
if( event==EVENT_COMMIT ) {
double min,max;
GetCtrlVal(panel,PANEL_MINVAL,&min);
GetCtrlVal(panel,PANEL_MAXVAL,&max);
if( min SetAxisScalingMode(panel,PANEL_STRIPCHART,VAL_LEFT_YAXIS,VAL_MANUAL,min,max);
return 1;
return 0;
int CVICALLBACK StartCallback(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
int32 error=0;
TaskHandle taskHandle=0;
char chan[256];
uInt32 sampsPerChan,numChannels;
float64 min,max,rate;
int32 numRead;
float64 *data=NULL;
int log;
char errBuff[2048]={'\0'};
GetCtrlVal(panel,PANEL_CHANNEL,chan);
GetCtrlVal(panel,PANEL_RATE,&rate);
GetCtrlVal(panel,PANEL_SAMPSPERCHAN,&sampsPerChan);
SetCtrlAttribute(panel,PANEL_STRIPCHART,ATTR_XAXIS_GAIN,1.0/rate);
log = (int)log10(rate);
SetCtrlAttribute(panel,PANEL_STRIPCHART,ATTR_XPRECISION,log);
SetCtrlAttribute(panel,PANEL_STRIPCHART,ATTR_POINTS_PER_SCREEN,sampsPerChan);
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,chan,"",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",rate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,sampsPerChan));
DAQmxErrChk (DAQmxGetTaskAttribute(taskHandle,DAQmx_Task_NumChans,&numChannels));
if( (data=malloc(sampsPerChan*numChannels*sizeof(float64)))==NULL ) {
MessagePopup("Error","Not enough memory");
goto Error;
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
SetCtrlAttribute(panel,PANEL_STRIPCHART,ATTR_NUM_TRACES,numChannels);
SetCtrlAttribute(panel,PANEL_START,ATTR_DIMMED,1);
ProcessDrawEvents();
gRunning = 1;
while( gRunning ) {
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,sampsPerChan,10.0,DAQmx_Val_GroupByScanNumber,data,sampsPerChan*numChannels,&numRead,NULL));
if( numRead>0 )
PlotStripChart(panel,PANEL_STRIPCHART,data,numRead*numChannels,0,0,VAL_DOUBLE);
ProcessSystemEvents();
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
SetCtrlAttribute(panel,PANEL_START,ATTR_DIMMED,0);
if( data )
free(data);
MessagePopup("DAQmx Error",errBuff);
return 0;
int CVICALLBACK StopCallback(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
gRunning = 0;
return 0;
Finally, in the code there is a CVICALLBACK type of functions...Where can i find more about this?
Any help would be appreciated to the most..
CKary
(2,752 Views)
(2,743 Views)
