Can't read acceleration measurements of accelerometer from Ni Daq
I am trying to read an acceleration measurement from an accelerometer using the NI dAQ. I am using an ac coupled 3 axis dactron acclerometer. it needs an input current to read from accelerometer. I have an ni usb 6259. do i need another instrument to measure the acceleration or should the daq suffice?
(2,988 Views)
You need signal conditioning for your application.  See linke below for all of your options.
Yik
http://sine.ni.com/np/app/main/p/ap/daq/lang/en/pg/1/sn/n17:daq,n36:11,n21:11
Kudos and Accepted as Solution are welcome!
(2,974 Views)
