Can the 6713 AO's be stacked in parallel to get higher current?
The 6713 only has +/-5mA drive.  I need a bit more.  Can they be paralleled to increase current?
(4,169 Views)
Accepted by topic author MickF
I would not recommend that.  Use an amplifier that can give you more current output.
(4,167 Views)
