Can you trigger with CWAIPoint?
Hi
If I am having a constant volatge input to a channel in my DAQ card, I need to sample only one point - CWAIPoint should work. However, I would like to acquire it only when I am meeting some trigger conditions, say another voltage in another channel. This is easily done in CWAI. Is the same feature available in CWAIPoint, or is it better to use CWAI itself with number of scans = 1?
Rajeev
(2,780 Views)
Hi Rajeev,
The CWAIPoint does not have the capability to support triggering. It is simply for software timed single point acquisition. For more complex measurements that use triggering you will need to use CWAI.
-Sal
(2,776 Views)
