Cannot Find PXIe-1090 in MAX
I have not been able to get it to work since the BIOS update. I cannot revert because it was a security update and does not allow reversion.
Message 11 of 14
(188 Views)
Hi, I'm from NI Tech Support. We're currently investigating this issue and would appreciate your input. Could you please share the following details?
  • Laptop model(s)
  • Chassis and module(s) involved
  • Operating system(s)
  • Firmware version(s)
  • Did it work before the BIOS update?
Please share any other relevant information you think might help us review the issue, thanks in advance!
Message 12 of 14
(144 Views)
See reply here.
Message 13 of 14
(131 Views)
  • Laptop model(s)
    • Dell Pro Micro Plus QBM1250 (a mini-PC)
    • The Thunderbolt port is via an option you can specify when ordering the PC, a PCIe to Thunderbolt expansion port.
    • PXIe-1090, PXIe-4468
    • Windows 11 Enterprise, 24H2
    • 25.5.1f0 on the 1090 (can see when plugged into Dell Precision 3590 Laptop), 25.5.0f269 on the 4468,
    • No, it never worked. I’m currently running BIOS version 1.8.1. That was updated from 1.7.0 a few weeks ago when Dell released it. Neither of those versions worked.I tried downgrading to 1.1.2, 1.3.0, 1.4.4, and was blocked when it tired to flash by the message: “BIOS Update blocked due to unsupported downgrade.” Downgrading to 1.6.2 was allowed, but didn’t change anything shown in NImax or add any other relevant BIOS options.
The symptom is the same as above: the PXIe-4468 module shows up in NImax and passes self-test, but the PXIe-1090 does not show up in NImax, and cannot be used with the Python SW we use to run our experiments becuase trigger routes can't be found.
The same PXIe-1090 and 4468 plugged into a Dell Precision 3590 laptop work fine.
Message 14 of 14
(110 Views)
