Cannot connect WLS-9163
I want to set up an NI WLS-9163 with an NI 9205. However, the Measurement & Automation Explorer does not detect any device when I plug the NI WLS-9163 with an Ethernet cable.
I tried every instruction in the manual. You will find a print screen attached, showing the device’s configuration.
We also tried to plug a NI 9171, and the software could detect it.
What steps can I take to resolve these issues?
Regard.
(3,730 Views)
Can you tell me the version of DAQmx you are using?
Antoine
(3,666 Views)
I am using NI-DAQmx 15.5.
- Romain
(3,662 Views)
Could you read (in order) and follow the steps through this documents :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015BWHSA2&l=en-US
http://digital.ni.com/public.nsf/allkb/9510F0B2E37BBFB5862578150063DF91
http://digital.ni.com/public.nsf/allkb/698876802BF64448862574C80055F513
http://digital.ni.com/public.nsf/allkb/85F0E0316EFBA819862575A2006B8D63
http://digital.ni.com/public.nsf/allkb/82611415939F73F2862577A0006B4C09?OpenDocument
Best regards.
Louis
National Instruments France
(3,656 Views)
the documents aren't available anymore. Is it possible to reupload or share the documents again. Thank you very much in advance.
Janick
(1,888 Views)
