Cannot get PCI-1408 to capture image
Hello
I'm using a PCI-1408 card with a HP Compaq dc7100 PC running at 3 GHz (Pentium 4) on Windows XP and cannot capture an NTSC image through the basic Measurement & Automation explorer.
I know the signal is good (connecting to a separate monitor). I'm trying to duplicate two other similar PC set-ups using similar image sources which use the PCI-1409 and PCI-1410 cards and so have adjusted the card settings to match.
In the menu Advanced NTSC properties in Measurement & Automation explorer, have adjusted the Sync detect level to generate 2 different responses:
(1) with Sync detect < 50mV, the error "<IMG_ERR_TIMO> wait timed out - acquistion not complete" is generated
(2) with Sync detect > 100mV, the error "<IMG_ERR_VLCK> can't lock on video source" is generated
Reading the forum for solutions, I haven't found a way to diable hyperthreading on this PC (not sure if this is an issue). Also, have tried using previous NI-IMAQ software - i.e. version 2.6 and version 3.0.
Can you offer any advice, please.
Thanks.
(2,955 Views)
Are the jumpers on the board set up correctly?
http://www.ni.com/pdf/manuals/321325c.pdf
Not sure what versions of IMAQ and MAX will work with that card, the docs call out IMAQ for Win95/NT.
(2,948 Views)
Yes have checked the jumpers - it is set-up for use of BNC connection for video input channel 0.
(2,939 Views)
