Capture AO with AI and synchronise to TDMS
How do I save the output that I write to a AO channel, along with some input from a different AI channel, to the same TDMS file so that they are syncronised?
Summary of what I want to do:
- I have some signal that I want to write to a AO channel. Call it x.
- I have some signal I want to capture from a AI channel. Call it y.
- I want to save x and y to a TDMS file so that x and y are syncronised.
The way I have been doing it in the past is to feed the output from x back into a new AI input and then capture that. This wastes an AI channel, and I'm sure there's a better way to do it.
(3,144 Views)
For your analog input virtual channel, you can select your AO channel vs ground as and AI channel.  You will have to right click your physical channel control/constant and click I/O Name Filtering... Then make sure you select internal channels.  Then you can just use channel expansion to select both your AI channel and the ao0_vs_gnd channel.  You will still need to use a setup similar to the Multi-function Synch AI-AO example to physically synchronize the AI and AO, but this way you won't waste a channel.  Just to verify, I created an AI task and selected all physical channels, as well as ao0_vs_gnd and I didn't get a reserved error.  You will obviously need to change your DAQmx Read to read multiple channels and then just write to the TDMS from the the Read VI.
Sean
Applications Engineering Specialist - Semiconductor Test
(3,119 Views)
