Challenge in searching DAQ Module with 14 Analog output
Hi, I am looking for DAQ module which supports 14 Analog Output, 8Analog Input and 4 Digital(PFI lines/PO). NI 9264 DAQ module is supports 16 Analog Output. But I am searching for module which will supports all of the above mentioned category channels. Can anyone please help me with the module if that is available with you?
Thanks a lot!!
(828 Views)
Most NI multifunctional IO modules only have 2 or 4 AO. I would suggest to use multiple C series modules in a single cDAQ chassis. You could use:
  • two NI-9381 (8 AI, 8 AO, 4 DIO for each module)
or
  • NI-9264 (16 AO) + NI-9201 (8 AI) + NI-9402 (4 DIO)
https://tmesystems.net/
(795 Views)
Thanks a lot!!
Why exactly it has to be a single module?
Santhosh
Soliton Technologies
(785 Views)
Exactly, it has to be in one single module mentioned categories of channels. There is NI USB 6353 available, but it has only 4 Analog outputs.
(780 Views)
And what is the constraint to be a "single" module? cost? size? features?
What if such a module doesn't exist? or you need PXI, are you willing to go that route?
Santhosh
(773 Views)
