Change Detection Support on PCI-6232
Can someone tell me whether the PCI-6232 supports change detection on its Digital Input lines.  The spec says it can but if I try to programmatically configure this (via the .NET interface) I get an unsupported operation error.
(3,493 Views)
Hi Martin,
Which port are you using?
http://digital.ni.com/public.nsf/allkb/8914FA5E30971E0C86256FEF005760FF?OpenDocument
It seems PCI M Series can only use change detection on port 0.
Kind Regards,
Owen.S
(3,473 Views)
Owen,
We are trying to configure Port 0, Lines 1 and 4.  Have an encoder connected on Port 0, Lines 0 and 2.
Martin
(3,469 Views)
Hi Martin,
Could I ask to which document you were refering to in your first post?
Kind Regards,
Owen.S
(3,438 Views)
Owen,
Found references on the following links.
http://sine.ni.com/ds/app/doc/p/id/ds-38/lang/en
http://zone.ni.com/devzone/cda/epd/p/id/1739
regards
Martin
(3,420 Views)
