Changing Input Coupling for Nidaqmx using Visual C++
I am trying to program a high speed data acquisition card using Nidaqmx libraries and Visual C++ 6.0. I have not been able to find a function to change input singnal coupling for analog input channels (From AC to DC etc.)
Could you please suggest how I can achieve this.
Thank you,
Saurabh
(3,537 Views)
I found the function in the nidaqmx.h file. I would, however, like to point out that the funciton is not available through the function reference help files. For users who are migrating from traditional ni-daq to nidaqmx it is very difficult to find unless you dig it up in the header file itself.
Thank you,
e-tan
(3,531 Views)
Hi e-tan-
I'm glad you found the function you needed.  FYI, for future searches you can find this and other properties in the NI-DAQmx Properties categories listed in the NI-DAQmx C Reference Help.  This particular property is listed as a DAQmx Channel Property ( DAQmxSetAICoupling ).
Thanks-
Tom W
(3,521 Views)
Thank you Tom,
I appreciate your response.
Best Regards,
e-tan
(3,516 Views)
