Changing filter cut off on M series cards
I want to sample 32 channels with the M series 628x series cards. But at the maximum sampling rate that would afford me a 15Khz sampling per channel. To avoid aliasing I need an analog filter at 5 KHz. The M series card only offers a 40 Khz filter. Is there anyway to change this filter's cutoff (-3db) to 5 Khz? Any suggestion is greatly appreciated, but I'd like to avoid building a 32 separate analog filters in front each channel.
(3,432 Views)
There is no way to alter the M Series lowpass filter cutoff frequency. You will need to apply separate signal conditioning before reading the signal in with your device. I recommend using the SCC modules, which offer filtering options. You can view their specs at: http://www.ni.com/pdf/products/us/4daqsc253-265_194-196.pdf .
The SCXI-1141/1142/1143 is a filtering module that offers a programmable filtering from 10 Hz to 25 kHz. You can view their specifications at: http://sine.ni.com/nips/cds/view/p/lang/en/nid/10324 .
I hope this helps,
Sean C.
(3,417 Views)
I'm really worry about this issue.
Our customer has a PCI 6289 and he bought it becuase on the catalogue it said: "Programmable lowpass filter"
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14115
He wants to use the antialiasing filter option with a cutoff frequency of 1KHz.
The answer you wrote means that he cannot use any cutoff frequency, just 40kHz.
So , why it is written "Programmable lowpass filter"?
what is or are the ranges of the "Programmable lowpass filter"?
Why isnt documented on the M series specification?
Dalia
Dalia Russek
Senior Technical Support Engineer
National Instruments ISRAEL Ltd
(3,377 Views)
Hello Dalia,
The PCI-6289 does have a 40 kHz programmable lowpass filter.  The term "Programmable" means that this filter can be programmatically enabled or disabled.
This information is documented in the 6289 Device Specifications as "Small Signal Bandwidth (-3 dB)" at:  https://www.ni.com/docs/en-US/bundle/pci-pxi-usb-6289-specs/page/specs.html .  This information can also be found in the M Series Help under "Analog Input Lowpass Filter" at:  https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/371022l.pdf .
I hope this helps.
Sean C.
(3,361 Views)
