Changing units on temperature graph
What is the best way to change units from C to F and back on the graph showing temperature vs. time?
(3,514 Views)
Accepted by topic author ValeraM
I recommend making a case structure with a boolean control to toggle the case.  Within the case, scale the signal for degC or degF, and also have a property node for the graph by right-clicking the graph»create»property node»Y-Scale»Name Label»Text   and change the text to degC or DegF accordingly.
Best,
Adam
Academic Product Manager
National Intruments
(3,495 Views)
I think this may work.
Thanks, Adam
(3,490 Views)
