Channel 0 on SCXI -1124 not working.
We have a SCXI-1124 card that was working then channel 0 quit operating and I was wondering a quick way to test the card to see which IC is bad, I don't have a drawing of the card so any help would be great.
(2,880 Views)
Hello kwb3772
Thank you for using our discussion forums.
To ensure that channel is truly damaged can you try using this module in another slot of the SCXI chassis?  If you are still unable to output a signal then we can be sure that the channel is blown.
Knowing this it is best to proceed by speaking with an Application Engineer, and have the SCXI module repaired.
You can create a service request at the following link
Select Phone NI, and fill out the needed information.  In order to provide the most efficient support, can you ensure to select the proper product, and mention repair or damaged in the problem summary.
Chris_K
(2,856 Views)
