Check a ADC with PXI-6259
I use the M Series DAQ PXI-6259 in LabWindows/CVI ADE, and now I want to verify whether a 8-bit ADC working properly or not.
The input of the ADC is a sine wave and I acquire the 8-bit digital data (in Digital Format or Port Format ) each time the A/D convertion is completed. Next I want to regenerate the sine wave with the acquired digital data using 6259.
The analog channel supports only 64-Bit Floating-Point Numbers data format but not Unsigned and Signed Integers data format, have to I scale the acquired digital data to 64-Bit Floating-Point Numbers data format according to the amplitude of the sine wave and then regenerate the waveform ??
If so, have to I specifie the APFI0 or APFI1 as the source of the DAC reference voltage?
Thank you very much for your help.
Sxs707
(4,684 Views)
Accepted by topic author sxs707
The DAQmx Write does support both signed and unsigned writes. Open Library>NI-DAQmx>Write Functions and find DAQmxWriteBinaryI16, DAQmxWriteBinaryU16, etc.
(4,680 Views)
Hi,Dennis,
(4,662 Views)
Hi, Dennis,
Thanks very much for your help .I'm so sorry but i make a mistake in the above reply and now i try my best to convey my question clearly:
There are both DAQmxWriteBinaryI16 and DAQmxWriteBinaryU16. If I write the native data acquired from ADC to 6259 without any scaling using one of the two functions, have to I specifies both APFI0/APFI1 as the source of the DAC reference voltage and the amplitude of the sine wave as the value of the DAC reference voltage? Thanks.
(4,655 Views)
What is the input range of ADC that you are testing? I'm not sure about the APF10/APF11 but offhand, I would think you want the reference voltage of the ADC and the 6259 to be the same. I don't see where you would use the amplitude of the sine wave.
(4,653 Views)
Hi ,Dennis,
Thanks for your help, now I see that I do need to set  the reference voltage of the ADC (but not  the amplitude of the sine wave ) and the 6259 to be the same. Thanks again.
(4,642 Views)
