Clocked DIO
The M series of NI MIO DAQ devices include the so called “correlated digital IO” capability, which permits synchronizing digital IO with other operations, for example with triggered AIO. The E-Series does not have such a capability.
How can I do a clocked/triggered digital acquisition using for example the PCI-6034E or one PCI-6052E  DAQ card?
Thank you
A. V.
(3,627 Views)
Hi Grivilla!
Here I found a KB, where it is written how to synchornise digital output and analog input on e-series.
http://digital.ni.com/public.nsf/websearch/851A80A7AB2885E086256F4D000610E6?OpenDocument
I hope that helps you so far!
Greetins, Mona
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,616 Views)
Hi A.V.-
Please note that there is neither clocking nor triggering capabilities available for digital I/O operations with E Series.  So the example linked from the previous post does not guarantee or provide synchronized digital or analog operations beyond [possibly very] unreliable software timing.  As you mentioned, you must upgrade to an M Series board if you need the ability to correlate digital operations with other measurement types.
Hopefully this helps-
Tom W
(3,610 Views)
Thank you for your replay. I think, getting an M-series will be best thing to do. snif...
(3,597 Views)
