CodeBlocks, C++, mingw-w64 compiler, Windows 10, Errors: Undefined reference to `DAQmxCreateTask' and others.
I wonder if anyone could help me. I'm programming a NI-DAQmx application in C++, using CodeBlocks WxWidgets.
I'm using a recent version of the mingw-w64 compiler and Windows 10.
When compiling, I'm getting the undefined reference errors to the DAQmx___ statements:
`DAQmxCreateTask',
'DAQmxClearTask',
'DAQmxCreateAIVoltageChan',
and others.
I have included NIDAQmx.h, NIDAQmx.lib files in the project. I've searched for a few days, and read posts around the problem, read about wrapper files, and hacks within NIDAQmx.h, but can't seem to find anything to help.
Code snippet:
#include "Incoming_Signals.h"
#include <math.h>
#include <limits>
#include "NIDAQmx.h"
int PxiError = 0;
TaskHandle	taskHandle=0;
float64		data[32];
char		errBuff[2048]={'\0'};
int32      	readstuff;
#define DAQmxErrChk(functionCall) if( DAQmxFailed(PxiError=(functionCall)) ) goto Error; else
double AnalogInputs(unsigned int t)
   // DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"PXI1Slot4/ai0:31","Voltage",DAQmx_Val_Cfg_Default, -10.0, 10.0, DAQmx_Val_Volts, NULL));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	// DAQmx Read Code
	//(TaskHandle taskHandle, int32 numSampsPerChan, float64 timeout, bool32 fillMode, float64 readArray[], uInt32 arraySizeInSamps, int32 *sampsPerChanRead, bool32 *reserved);
	DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1,10.0,DAQmx_Val_GroupByChannel,data,32,&readstuff,NULL));
	//Error handling
    Error:
	if( DAQmxFailed(PxiError) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
Any advice would be appreciated,
Paul
(2,859 Views)
Hi PaulJG,
Do you manage to solve your problem?
BR,
Maxime
(1,864 Views)
