CompactDAQ triggering off a load from 9237
I am trying to trigger off of a load threshold from a load cell monitoring load. It seems that the 9237 doesn't directly have that functionality like some of the analog in modules. I also need to capture a second or two of pretrigger data. My programming skills are at a CLAD level and was wondering if A: this is possible (which I thing it is running a bunch of loops) B: or if anyone has attempted this with any success?
Matt
(3,886 Views)
Accepted by topic author mgrimm
Hi Matt,
 With the 9237, you'll still be able to do an analog software trigger. There's a really good example here that you may find very helpful.  The example was built for a 9233, but you can change the task to a strain/custom voltage with exe task to suit your 9237.  I gave this a shot with a simulated device and it worked well.  Let me know if you have more questions after checking that out.  Have a good one!
(3,867 Views)
HI,
The link is not working. Could you please provide the link again?
(2,023 Views)
