CompactRIO Custom module without cRIO-9951 MDK
I need to create a custom module to compactRIO without cRIO-9951 MDK.
I have an eeprom programmed with content similar to module 9211 to
make some tests.
Now I have to connect the eeprom in the 15 pins connector to see if
Labview detects my module as 9211.
After that i will program an eeprom with my module data and expect
labview detects my module
My problem is that i dont know how to connect the eeprom in the 15
pins conector.
Does anybody can help me?
Best regards all
(4,020 Views)
Hi anonymous,
Unfortunately the documentation for the connector interface is only available with the MDK, and the license forbids distribution.
Jeremy_B
(4,007 Views)
